Discuss Left most pipe tap leaking under boiler - please help! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Peter TD
I have a dripping leak coming from one of the black taps under my boiler. It means I need to top up the pressure every 2-3 days.
The pipe the tap on is a hot pipe when the boiler is on. It is the most left pipe on the image!
Could anybody please help/tell me what's wrong and how to fix?
Thanks!
Is it leaking from a nut or the actual valve part ?
as above does leak from the chrome nut or from the middle of the black handled tap? If so you may need to get an engineer out to change that over.
It's coming from the black tap itself, looks like it's from the screw in the centre of he black tap, but can't tell for sure and it doesn't tighten... is it expensive to get that changed?
new valve sorry to say, best enlist the services of a gas safe engy
May not be coming from that, could have a leak inside boiler and its running down the pipe, get some one to check it out
Reply to Left most pipe tap leaking under boiler - please help! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have done pressure test for 2" high pressure pipe line by closing the pipe with rubber plugs at the ends. It was 3 bar and I kept it for 24 hours. Its shows a pressure drop of 0.5 bar. The pipe line is fully exposed and I couldn't find any leak on them. What might be the problem. If somebody...
