M
mikeoc1962
I've a Blanco branded monoblock top lever tap that's leaking through the top lever.
The lever itself comes off easily enough and opens onto a small well with a steel ball joint and the water is pressing out through this area as the lever is moved.
Do I need to scrap the tap and buy another or is a replacement cartridge/washer needed?
Any advice would be welcomed.
Many thanks
Many thanks
