Discuss Leaking toilet - how do I fix? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello, my toilet is leaking please see the attached video and photos, what is the best way to fix this please, it seems that it might be simple but not sure where to start or what to buy, thank you in advance!
The old home owner put the putty around the fixing, it’s clearly not doing anything!
  • IMG_1070.MOV
    9.5 MB
The pan connector doesn’t look all the way onto the spigot best to remove the toilet and see if a stnd bent one will do
Reply to Leaking toilet - how do I fix? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello I have a condensate pipe that appears to be leaking at the joint. How do I fix the leak? Would something like plumbers putty around the joint work or does it need to be some other compound? Can I simply pull the pipe and joint out and then put the compound round it Thanks
Hello! We have a wobbly toilet seat… it’s a back to wall toilet and whilst one fixing is secure the other is not, and it looks like the fitter didn’t really attach it all. How do I go about fixing this please! The seat in question is from Qualitex.
hi i have a drip leak from the bottom of this pipe see attached how do i fix it is there a video that would help me cheers
Hi, I fix what I can around the house myself and have fixed a few toilets but I need help with this one. This toilet keeps running and stopping, running and stopping, etc. I've cleaned the rubber flapper itself and at the point that it contacts the reservoir, so I don't think it's leaking from...
Hi there. I have a Cersanit close coupled toilet which as started leaking between the cistern and the bowl when flushed. I've taken the cistern off and this is what I see. I'm assuming the issue is with the silicon gasket (please see attached photos) but can't seem to find a replacement...
