Discuss Leaking sink waste pipe replacement? in the USA area at PlumbersForums.net
Hi, the waste pipe under the sink is leaking at the push fit connection. Is there an easy way to seal, or should I replace with a compression fitting? Leak in yellow circle in grey pipe. Thanks
Best to replace the trap for a compression outlet one
Reply to Leaking sink waste pipe replacement? in the USA area at PlumbersForums.net
