Discuss Leaking kitchen tap (picture attached) in the USA area at PlumbersForums.net
I have a leaking kitchen tap. The leaks are coming from where the arrows are in the picture. I bought a trap sealing ring (Trap Sealing Ring 32mm - https://www.toolstation.com/trap-sealing-ring/p56734) to try and fix the leak, but it is still there.
What solution would you suggest? Is this something I should get a plumber to sort or is there an easy fix?
If you can see the rubber, then that’s a no-no. I’m not a fan of that style of trap arrangement, and as a personal choice would be replacing for a more adequate set up. It’s doable if you’re diy skilled, or if you want to use the services of a plumber, the choice is yours.
If I may be brutal, I see at least one nut is cross threaded and others look mullered from somebody using grips, I see pipes going in a direction I don`t like and by having it all replaced with new I believe you would have more space there so pay somebody is my advice.
Reply to Leaking kitchen tap (picture attached) in the USA area at PlumbersForums.net
Hi, My Blanco Kitchen Tap Model Swift BM1420 is leaking. Please see attached photos for details of where water leaks from. What I've done so...
Hi there I have attached a video below, showing where my kitchen tap is leaking from, is this possible to repair by replacing the hose pipe or...
Forgive my ignorance, with this basic question, but I seem to be struggling to both understand, search for, and source, the appropriate washer...
I have fitted a new set of mono mixer taps to new bathroom basin pedestal and for some reason, I’m unable to get the tap hole/base ring...
1K
Rad is leaking from TRV valve, seems to be seeping out of where the pin comes up. I tried tightening up the nut below the pin, but that didn't...
