Discuss Leaking ceramic disc spindle in the USA area at PlumbersForums.net
Hi all,
First time renovator and registered plumber. I'm replacing my old full turn taps with quarter turn taps that have ceramic disc spindles, but the new taps seem to randomly gush hot water while the handle is turned off after they have been used, any ideas on what could be going wrong? We have already placed a new tempering value on the hot water system
Hi all,
Gush, or just residual water?
Reply to Leaking ceramic disc spindle in the USA area at PlumbersForums.net
I have recently brought new mondella pin lever 1/4 turn ceramic taps - Mondella Black Resonance Pin Lever Wall Top Assembly -...
3K
Some advice please about a really worrying problem. I live in a terraced 2 bed room house. 10 days ago the gas combi boiler stopped heating the...
Can you get water hammer from ceramic discs on tap valves? Have been to a job where is it sounds like its coming from there. But I know this isn't...
3K
Hi, I had a leaking basin mixer tap. The Methven brand tap was leaking through the top. I was able to source 2 new replacement ceramic cartridges...
Deleted member 120897
Hi All I need to replace a leaking tap (separate, not a monobloc). I notice screw fix do 3 sizes, 8mm, 9mm and 10.5mm, is this just the diameter...
3K
