Discuss leak through handle of push fit service valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
Nobbyone
Can anybody tell me if this service valve on can be replaced or repaired as it leaks from the spine of the handle when closed. I looked on-line to try to match it with an existing make but with no luck. Looks like a compression to tap connector type.
Does anybody know if it can be repaired/tightened/replaced with a modern system?
Thanks for your help.
Yes sorry pal, had to rush out, yep put a normal sv on it with a new connector and washer to the valve.
Those plasic valves are ok untill you move them, but saying that the brass ones can somtimes leak.
just had another look at the pic, its a bit unclear but what is your valve connected to upstream
if you mean down stream then its mlc pipe (new build crimp)
Reply to leak through handle of push fit service valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
In the photo there is a grey 32mm push fit elbow between the sink trap and down pipe. I want to replace the elbow with a "male" push fit tee...
A
Hi, I am replacing a leaking push fit flexi tap connector under the bath with a compression fitting flexi. The problem is that the old pipe seems...
Hi Just had a new bathroom installed with a toilet bowl that reaches the back wall. Its has a bottom entry cold feed to the cistern. The fitter...
1K
i have 3 sottini toilets with a compact cistern. It has an ideal standard dual flush mechanism. 2" entry The ideal standard is poor quality in...
1K
Been in property about 10 years and the valve on the (round/bunded) Balmoral tank has always been in pretty rusty state. Tank is 5,000 litres but...
1K
