Discuss Leak sealer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bright spark
Just putting a shout out to all d lads to see why d best leak sealer there is out there on the market. Must be suitable for underfloor heating pipe work.
I have a call out, might drop a bar over a week. Checked it out. No obvious leak on boiler, safety valve dripping, auto air vents, dodgy expansion vessel. All visible pipe work, heat exchanger leak etc.
Gonna pressure test the under floor zone by zone.
Any thought appreciated
I can't think of its name but it's blood red
Oxy somthing
Ask croppie he might know it's name Bassetts do it
Plumb7
Yea, Oxypic I think it sounds like. Bassetts stock it I think is correct.
It is a bit like red stag jointing in looks. You have to get system very hot and then put I'd directly into the system, preferably as close to leak as possible. It does a hard seal where it hits the oxygen, - hence the name.
It is both an inhibitor and a sealant
That's the one mate great stuff
I've used it on a couple of pressurised systems that wear dropping like lead balloons and sealed no problem
First time I used it was on an outside Warmflow oil boiler at a rented house. Boiler was flooding water from it, - must have been a crack in weld. I pulled stat out and got the Oxypic directly above that side of boiler. It was a sealed system and sealed instantly.
But I tried it on another boiler and it never worked
Have you used it? I haven't read about it yet. Guess it is a soft seal?
Used it once at a pinch worked ok someone from here recommended it
Good to know. Handy for an emergency, - like for some elderly person in mid winter with a leaking boiler that can't be just replaced quickly.
I had years ago tried Fernox leak sealer, but found it never sorted a bad leak.
Reply to Leak sealer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and...
losing pressure
L
I have a pressure leak on my CH system. Our piping is buried in the walls (maybe a mistake) and the room-to-room pipes are now covered by flooring...
Dear professionals, could someone kindly advise on per below issue, please let me know if more pictures or details needed. I think my Auto Air...
Hi all not a plumber but am an engineer I have pressure drop in the system Worcester Bosch came back after repressureising the expansion vessel...
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem...
