Discuss leak on my imergence heater in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
alacn
its leaking at the top of the cylcinder at the immergence heater, what would you suggest to stop it from leaking?
Hi. Get it checked out as on occasions the leak is a result of the brazing failing within the immersion heater cap, which houses the electrics. Not a good mix.
Reply to leak on my imergence heater in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
Does anyone know a good, not super expensive, leak detection company in the London area?
PSxxxxxx
