Discuss Kw rating. Qn & Pn? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
wild nomad
Hi there. In relation to Kw ratings of appliances, does anyone know what Qn and Pn stand for? I often see these abriviations on the data badge.
Thanks in advance.
If I remember correctly Q is heat input, P is heat output. n is "nominal" which means some variation from stated figures is to be expected..
Thanks Masood. So, would you expect the numbers to be nett or gross?
Normally nett I think, but I could well be wrong on that. Never found anything to actually confirm that, including trainers on manufacturer's boiler training days!
Reply to Kw rating. Qn & Pn? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the...
Essaboy
E
Hi Could I ask for some help with a water flow rate problem. I have good mains water pressure on the ground floor. There is no tank in the loft...
1K
Hi apologies of this has been asked before but when you gas rate an appliance and trying to compare to the technical data, do you go off the...
Deleted member 120897
Hi I moved into a property where the pressure is slightly low and they have this super duper shower but pressure is somewhat lacking. I have had...
I have a Vaillant boiler and want to set d.0 to something sensible, right now it is set to auto and can range from 6 kW to 37 kW. Adding up my...
2K
