Discuss Knee operated valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Neil T
Subscribed
Hi, can anyone point me to a supplier of these valves please. They are from a knee operated trough/sink and the washers have gone. Can't source the washers or valves for love nor money. Any help would be appreciated. The actual sink has no manufacturers mark so can't go down that route :(
Can't you just replace the whole valve ?
Will send pics over to shower doc, cheers. Can't find exact valve anywhere as it works by a hinged box (can see in background on pic) and all i can find are lever and button ones. Don't even know manufacturer of sink as there is no stamp
Looks like a catering set up by your pic's try www.mechline if you cannot find it there phone thier tech dep who might put you onto someone who can help found them helpful in the past good luck .....regards Turnpin:smile:
Reply to Knee operated valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
I have an Arteform shower valve in my bathroom - top lever for the main shower head, middle for the handheld hose and bottom is the thermostatic...
Hi all, DIY rookie and have an issue with malfunctioning diverter valve - water currently flows through both tap and shower head regardless of...
Hi all, I have an issue with our shower's hot water. The shower is operated using two separate taps for cold and hot water. When the hot water tap...
I am generally a decent handyman, can usually make 2+2=4 and take care of most things to avoid troubling experts with just the basics, but know...
Context for issue: Last winter the temperature switch on my boiler shorted somehow, the boiler was then running WAY too hot and ended up...
