Discuss Kitchen water feeds and UFH in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
flappy8
The kitchen/diner is going to be fitted with UFH. It will be a block and beam floor with a small later of sharp sand to level, 100mm insulation and then a 55mm anhandryte screed. Should the water feeds to the kitchen be pipe in pipe on the block/beam under/in the bottom of the insulation or in the screed layer? Is there a freezing problem below -I see a heating problem if it's in the screed because the pies will have to cross the UFH at some point.
Any thoughts welcome
Hi there the last time I done what youre proposing cut channel in insulation and laid pipes on bison floor in 25 mm insulation but dare say someone may shoot me down for this..brum
I usually put the cold in under the insulation, in lagging. Then the insulation with the hot on top in lagging again. Followed by the ufh. You have to be clever with how you run the hot so it doesn't muck h up your ufh runs.
When I say insulation actually mean 25 mm lagging..brum
As said works fine, we do that all the time. Have got to be careful with the cold not picking up any heat to.
I'm always paranoid about that, especially when the house is on a loop so the hot pipe will be hot all the time, keep them well apart!
Reply to Kitchen water feeds and UFH in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I would really appreciate your eyes on these pictures - What do you see ? Does anything look strange about the Rockwool insulation to...
N
Hi - some advice would be appreciated. We are doing a refurb and are having water based underfloor heating installed. The top layer will be 15mm...
1K
Gnorw er’uoy
G
Hello, I am renovating a small bathroom in an apartment on the 5th floor. Heating is electric, no gas or oil. I have four (related) questions...
Hi, I've got a leak coming from the loft into a bedroom which I think is caused by water overflow from feed and expansion cistern (see attached...
2K
Ok I have been dealing with this problem for over a year and finally have to ask for some help as backflushing every 2 weeks or so is getting very...
1K
