Discuss Jointing compound on pushfit? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
DIYPaul
Hi, I'm a novice when it comes to plumbing. I've used compression fittings in the past, and have applied jointing compound.
With push-fit copper fittings, do you still need to use jointing compound?
No no no! :) The instructions will tell you to make sure you have a smooth cut (not a hacksaw) and ensure that any burrs are removed before pushing the tube a set distance into the coupling. Some let you use silicone lube to make it easier to push the tube in and reduce the risk of damaging the 'O' ring.
Follow the mfr's instructions to the letter!
no jointing compound required, i some times use spray lube, especially when i am using 28mm
put solvent cement all over the o ring rap it in densil tape then apply tar all over it
Or maybe heat it up and see if you could run some solder round it, just in case !
Reply to Jointing compound on pushfit? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
