Discuss JG Speedfit NEW Lay flat pipe test results in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
Guest123
Speedfits new lay flat barrier pipe which is as flexible as a rubber hose put to the test. By the way the testers at JG have had too many joints (and I don't mean push fit ones) and well just watch the vid........
LAYFLAT PIPE PUT TO TEST - YouTube
Looks like a clip from children's tv something that would be presented by Richard Hammond
I look forward to trying it myself. As for the threading through joists test....really!? Holes that size in standard joists, I think not!
It's funny as they never admited the coils were an issue until they produced something that isn't like a coiled spring.
Looks good stuff.
Looks good stuff.
We had to use speedfit at eagaheat and I hated the pipe. Hep was a lot easier to thread.
I find hep to be the worst for coiling up! Speedfit and poly seem to straighten out much better.
Yeah, it's a stupid advert, but we've all sat and watched it!
It does look good. I hate the way it fights against you when you're running a load out.
I do a fair bit of work in offices where we run it above the suspended ceiling. Long runs, (often the insurers don't want any joints). It can be a right pain in the backside!
Reply to JG Speedfit NEW Lay flat pipe test results in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with...
New LPG installation with 2x 19kg cylinders outside, plus change-over regulator with isolator valve on output, then 10 metres of 15mm copper pipe...
2K
Hi there, thanks for your time to look at this record long post!! I work on the operational management side or a small building contracting firm...
H
HRP123
H
5K
