Discuss Issues with Ferroli Optimax HE Plus 31C in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I
iamrobjones
I recently moved to a flat which has a Ferroli Optimax HE Plus 31 C boiler. Up until recently it worked fine but as of late there has been issues when using only the over the bath shower.
The boiler has no problems heating the water, the ignition ignites and there is a constant flow of hot water. When using the shower, the pressure is a lot lower than it was previously and the boiler hardly ignites, or does for a brief time. the water temperture also fluxuates.
I've had a look on other forums and youtbe videos. I've turned the boiler off at the mains, which reset it and for a brief time this solved the problem. I've tried that again to no avail.
I've also had a go at holding down the reset button until i get the TS/T5 message and pressed the +/- on the hot water and heating to set them to 01 that i have read on other forums.
Is there anything else I could do? or that I am doing wrong? The water pressure is fine at 1.5.
Thanks in advance
Rob
Welcome along. Think you could do with getting a gas safe engineer in to check it over. We can't provide any DIY fixes on gas appliances and the likelihood is that a fix would be within the casing. It could also be an issue with the shower are all other outlets ok??
Reply to Issues with Ferroli Optimax HE Plus 31C in the Plumbing Jobs | The Job-board area at PlumbersForums.net
