Discuss Isolator Valve for cold water supply - correct size in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I was hoping someone here might be able to help. I need to replace an isolator valve on the inlet supply to a toilet. It's a 1/2" fitting - one end is connected to the water supply with a compression fitting, and the other end fits on to the thread of the toilet inlet valve. The problem is, I bought a replacement but it's too short (I assumed they would all be a standard size/length?), but comparing the two side by side I can see that the original valve has a longer 'collar' - not sure if that's what it's called, but I've attached photos of the original one in situ and the replacement. You can see the new one is a good 10mm shorter.
Unfortunately there is no wiggle room on the cold water supply so I need to try and find one the same size if possible. Has anyone come across these different sizes before and know where I can get one? I think I bought the original from Plumb Center (it was about 15 years ago!) but can't find a similar size in B&Q, Homebase etc.
Thanks in advance.
Thanks Gasmk1, that does look like the same one but they only seem to sell to trade.
https://www.NoLinkingToThis/p/strai...MI0vLlqKa84gIVZ7vtCh3NKQ9CEAQYASABEgIHzPD_BwE
Other places do sell them, such as toolstation, b and q, wickes, selco builders warehouse and all good plumbers merchants.
Thanks CBW, that Screwfix one looks right. Already tried 3 local plumbers merchants, B and Q and Toolstation. I did search on the Screwfix site yesterday but for an isolation valve (which looked like the shorter one I already have). I didn't realise they have a different name, i.e. service valve, which most seem to have the longer collar. Well at least I'll know next time. Thanks for all the help everyone, much appreciated.
Reply to Isolator Valve for cold water supply - correct size in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
