Discuss Isolating Valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
There are different backflow prevention devices for different scenarios.
Water Regulations are very strict on where these are installed. It is a legal offence to not use the correct backflow prevention on a system if its needed.
NO. A single or double check valve will do this as per the water regs.
In what circumstances would you need either a single or double check valve to prevent backflow?
depends on what fluid category you are dealing with, outside taps you should use a double check valve as a hose pipe could be connected to it and so increase the risk of backsiphonage. There are all also RPZ's which are used for zone protection mainly in comercial premmesis, but for domestic best to use a double check valve if in doubt
Buy the current water regs book. If you are in the arena where regs compliance is part of your daily grind, then it is invaluable. From a business perspective, a job quote is often made higher by the requirement to install specific valves/bits/methods in order to comply. Many cowboys ignore this, so the 'proper' plumber is at a disadvantage. If you show the customer the relevent paragraphs in the regs book, I have found this often (sadly not always) overcomes the price objection.
Always have a copy of my water regs in my van and a copy on my desk. I always have a look prior to a job that I havent done before or as a reminder.
single check valves are acceptable for use with fluid category 2 risks eg where mixing of hot and cold water supplies occurs, domestic softening plant, drink vending machine, fire sprinkling systems (without anti-freeze), ice making machines.
double check valves would protect against fluid category 3 risks eg water in primary circuits and heating systems, domestic wash basins, baths and showers, domestic clothes and dish washing machines, domestic hand held hoses with flow controlled spray or shut off control, hand help fertlizer sprays for use in domestic gardens
hope this helps
Reply to Isolating Valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
Can anyone help me with an ongoing issue I've had since I had an annual service on my combi boiler, which is a Potterton Performa 24. Literally...
The only hot tap that doesn't give constant hot water in the house is the bath tap. It gets hot for seconds and then goes lukewarm/cold. The...
1K
Deleted member 120897
Hello, I live in a two floor semi with a gravity fed conventional gas fired boiler (Potterton Kingfisher MF). The boiler is fed cold water from...
Hi all - hoping someone knowledgeable can help as I'm super confused by this.... I have a standard system / gravity fed boiler, large cold tank...
