Discuss Isar he 30 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
plumbbobshan
Hello lads ,
Been out to custards house boiler just gone off over night .
Isar he30 orange pcb box , got power to the black plug and the small glass fuse on the pcb is good .
No lights on switch panel and not working .
Any thing else to check before i get a new orange box ???
Check continuity through the on/off switch in the on postion I'd also check the pump and fan to see if they are jammed because they can blow the board and will do the same to a new one
I've had plenty of new v9 PCBs go. When I worked at the council we looked after loads of these and used to have a decent van stock on the van for them. Luckily they are easy to swap and I can change one in about two minutes, it takes longer to do your FGA and gas rates etc.
looks like it another 180 quid going into the back pocket of ideal........
if this doesnt cure the problem, the new boards duff as well, had that happen out of a sealed packet!! it took 4 months to get my money back off merchant/ideal
i had the same last week on a icos he12 i changed the orange thingy and it worked a treat.
i guess it must have while i was feeding the dog he paid me and off i went
Thanks lads , Will check to see if the pump and fan are not jammed up and the switch is working fine then get a orange box and replace it , but thats monday work. Now for some drinkys :17:
Reply to Isar he 30 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
