Discuss Is this safe? Open vented CH system has overflow capped. in the USA area at PlumbersForums.net
Good Evening All
I have a general question - I have searched the inter web and can't find an answer,
Recently I had an issue with a scalding hot header tank on an open vented system.
Boiler is fairly new, British Gas advised that it is being caused by sludge.
They cut out the offending pipes and re-piped. new header tank and capped the open vent into the f/e tank.
I am just a little concerned this is not safe. It is a Greenstar Ri Worcester Bosch bolier about 5 years old.
I looked in the installation manual but all the diagrams show the open vent into the f/e tank.
It's a 22mm feed from the f/e tank
I did check with BG and they assured me this is safe practice but I can't help wondering why they capped the open vent if it was just sludge. Just the replumbing should have sorted it surely. I questioned this and told it's the best way of sorting things.
Any thoughts would be really appreciated.
Thanks to all
is it a 22mm new pipe to the tank?
they have converted it to a combined feed and vent in theory without seeing it
If they have connected in the cold feed below where the vent is capped or if the cold feed was/is connected close to the vent then it should be OK, its also possible but unlikely in view of the re piping that they have converted your system to a semi sealed system, they would then have capped the vent, installed a non return valve in the cold feed and also installed a expansion vessel somewhere. If the boiler has a pressure gauge then you can tell as with the semi sealed the cold pressure will be ~ 0.35/0.5 bar and hot pressure ~ 1.0 bar, if not semi sealed the pressure will remain constant at 0.35/0.5 bar.
Reply to Is this safe? Open vented CH system has overflow capped. in the USA area at PlumbersForums.net
Hi, I'm new to the forum and just some background on myself. I have 4 years experience as a plumber but haven't worked in the trade in 15 years. I...
Hi, I'm after some help regarding my Father in laws heating system. He has had a local engineer around but hasn't had a fix and is very remote so...
1K
Hello, I have just installed a vented McDonald 250L thermal store, it is for multi fuel but currently just connected to a standard oil boiler in...
1K
I recently took off an end stop on the vent/expansion pipe over the heating header tank. I now know why it was capped off. When the 2 way valve...
2K
Hi all, Got a nightmare situation with a central heating system I recently adopted. It's an open vent system with a combined F&E pipe, with a...
2K
