Discuss Is this missing part called a Flange? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Thank you for you reply. I meant not aligned/ straight by unbalanced...Thank you for the link"Unbalanced" is a plumbing term usually to do with an incorrect adjustment of the lockshield valve on the radiator.
Are you meaning the radiator is not straight on the wall? If so there is probably something up with the mounting brackets on the wall. It's not the job of the white collar to hold the radiator in the correct position.
Apologies if I have got the wrong end of the stick!
Thank you Basher for the detailed explanation, highly appreciated. I was able to relate all your detailed explanation to my radiator. I was able to pull up the cover of the first valve.You need to isolate the radiator first before undoing the drain that you've arrowed, as follows:
Close the valve in your second pic fully clockwise.
Close the valve in your first pic, which, unless the white cover is actually the head of the valve, should pull off, revealing the stem of the valve underneath. You will need to turn the shaft fully clockwise, but count the number of turns, as when you're putting it all back, you need to restore the valve to roughly the setting it was on before.
Open the radiator bleed valve at the top to let air in so the radiator can drain.
Then open the drain you have arrowed, by turning it anti-clockwise. Hosepipe on the end or big bowl underneath!
if the water continues to run for ages, the whole system is draining, probably because one of the valves is not properly shut, or the drain is designed differently to normal!
The idea is while the radiator is draining, and only then, opening one of those bleed valves will allow air in and the water will drain out. Water should not come out of them during that procedure. It does look as if they have been leaking in the past, maybe because they were not quit tightenen up enough, though it's best not to tighten too much as you can damage the screw.Thank you Basher for the detailed explanation, highly appreciated. I was able to relate all your detailed explanation to my radiator. I was able to pull up the cover of the first valve.
I have found two bleeding valves, see please 'BleedingValves' image; should I open both of them fully (water will leak)?
The nuts to undo are the big vertical ones next to the radiator. You can slacken one, pull the pipe/valve away from the radiator ("un-stick it") and let the water run out. But you have the drain point to attach a hose (if you want) to use to drain the radiator before undoing those nuts. When undone they should slide back towards the radiator, allowing you to take it off the wall. obviously don't undo the smaller nuts under the valves!I am draining the radiator in order to align it; hence I am hoping to open the nuts in the 'leftValves' and 'rightValves' images. A video in youtube, drained the radiator from the valves; but the radiator did not have an angled valve.
You mean if water continues to flow during the draining process? Water coming out of one valve means it isn't fully shut, so turn it more and if that doesn't stop it, it's probably time to stop the project and call a plumber. If it's just a tiny leak, put something there to catch the water and try and get the job done before the container is full!!A last question, what if the water keeps flowing despite that the valves are closed. Is it a sign of a damage or should I just put everything back and use he radiator as it is?
I believe you meant the horizontal nuts, right?The nuts to undo are the big vertical ones next to the radiator.
got you, thank youI mean the ones like the one below:
If you undo any others you'll have a flood!
:View attachment 84442
Reply to Is this missing part called a Flange? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
