Discuss Is this a proper drain line transition from 2 inch to 4 inch? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
sierra256
Plumber replaced drain line under the bathroom. The drain line transitions from a 2 inch drain line to a 4 inch Y connector. Is this connection proper? I wonder if the Y connector should have a 2 inch opening to accept the 2 inch drain line to make this a proper transition.
Reply to Is this a proper drain line transition from 2 inch to 4 inch? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
