We had a Heat Loss Calc carried out by Octopus Energy for an ASHP they came back with 4kw ASHP
The current radiator sizing would suggest a HLC of 8.5kw. It's currently heated by an Ideal Logic H15+ Heat Only Boiler & 180L Hot Water Cylinder
We worked out that its likely to be around 6kw HLC.
The difference, between 6 and 4, appears to be the number of Air Changes per Hour (ACH) that they use. Apparently they use an ACH of 2.5?
That's for a 116 square metre, 4 bed detached new build (3.5years ago)
This shows the currently installed radiators, their heat output from Stelrad by size @ Delta 50'C, the Heat Loss Calc per room, the proposed new radiators needed (due to reduced operational temperature).
| Current
Radiator | Current
Radiator | Current
Radiator | Octopus Heat Loss
Calculation | Proposed
Radiator | Proposed
Radiator | Proposed
Radiator | |
Room Description | Description | Type | Stelrad
Radiator
Watt
Rating | Room Heat Loss (Watts) | Type | Description | Output at Design (Watts) | %
Coverage |
Bedroom 1 | H450 x L700 | K1/11 | 538 | 282 | P+/21 | H450 x L800 | 350 | 124 |
Bedroom 2 | H450 x L600 | K1/11 | 461 | 217 | K1/11 | H450 x L800 | 244 | 112 |
Bedroom 3 | H450 x L600 | K1/11 | 461 | 278 | K2/22 | H450 x L600 | 336 | 121 |
Bedroom 4 | H450 x L500 | K1/11 | 384 | 258 | K2/22 | H450 x L500 | 278 | 108 |
En-suite | H600 x L500 | K1/11 | 500 | 185 | K1/11 | H600 x L600 | 197 | 106 |
Entrance Hall | H600 x L500 | K1/11 | 500 | 296 | K2/22 | H600 x L500 | 348 | 118 |
Family Bathroom 1 | H600 x L600 | K1/11 | 600 | 206 | P+/21 | H600 x L600 | 260 | 126 |
Kitchen/Diner | H300 x L1500 | K2/22 | 1518 | 707 | K2/22 | H300 x L2000 | 702 | 99 |
Kitchen/Diner | Plinth Heater | | 1100 | N/A | K1/11 | H600 x L400 | - | 142 |
Landing | H600 x L400 | K1/11 | 400 | 117 | K1/11 | H600 x L400 | 166 | 142 |
Living Room | H600 x L600 | K1/11 | 600 | 591 | P+/21 | H600 x L600 | 276 | 47 |
Living Room | H600 x L600 | K1/11 | 600 | 591 | K2/22 | H600 x L600 | 355 | 60 |
Office | H300 x L1000 | K1/11 | 517 | 227 | K2/22 | H300 x L800 | 276 | 122 |
Utility | H450 x L500 | K1/11 | 378 | 76 | K1/11 | H450 x L500 | 159 | 209 |
| | Total | 8557 | 4031 | | | 3947 | |
