Discuss Is it safe to make recording studio in room with water and gas metre? in the USA area at PlumbersForums.net
Hi everyone,
I would like to put foam acoustic panels all over the walls and ceiling of a room to soundproof it, here are the panels:
The room has a water metre and gas metre (though there are no gas appliances in the property) in it.
I was going to use this to attach the panels to the walls / ceilings:
I have attached some pictures to help with your verdict.
We have lived at the property for 2 years and the only problem has been mould and damp.
My question is is it safe to install these panels??
Many many thanks for your help!
Olie
wouldnt want anything electric in with the gas meter personally
If there are no gas appliances in the property get the meter removed. Create access panels in your soundproof panels so the water meter can be read when it’s time, plus you’ll need access to the water stop tap.
Reply to Is it safe to make recording studio in room with water and gas metre? in the USA area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
