Discuss Internal soil pipe leaking at join in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all ,
Have a slight weeping leak on the underside of where soil pipe meets the tee join (seems like a little gap), at bottom ,after toilet upstairs is flushed ,highlighted area is in yellow leaking.
Hard to remove it seems tight , can I just get away with putting some ct1, fernox lsx or polypipe gap filling cement around gap at bottom of the join around where tee meets soil pipe as a permanent fix?
And if so what one would be best to use ?
Thanks.in advance for any help :)
let it dry out then warm with hair dryer warm not hot, wait 1o mins then give the joint a wipe with sovent weld.
Hi cjg, thanks for response , would the solvent weld make it watertight? I thought that was just for gluing the pipes together ?
Would I be better with something like LSX joint compound or CT1,pipe gap filler cement?
Thank you 👍
yes sorry i was just talking to some one about solvent weld, and on hear at the same time ooooops!!!!
what a sillly boy i am ,,, yes plumbers gold or sim should do the job...
Reply to Internal soil pipe leaking at join in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
