Discuss Intermittent EA fault on on Worcester Greenstar 38 CDi GC 47-406-38 in the Gas Engineers Forum area at PlumbersForums.net
Hi
Can anyone help?
I've got a problem with an intermittent EA fault on a Worcester Greenstar 38CDi Classic GC 47-406-38. I was called out to it but couldn't get it to go to fault- each time it fired up however, on a video the customer took he kept having to reset it.
I checked the gas rate (all okay), cleaned the condense trap (bit dirty nothing major), CPA fine, replaced electrodes (bit pitted) and leads. All okay until today and it went to fault again- customer reset it and working again. I said I'd have another look.
Could be either the fan or gas valve I "guess" don't want to replace either unless 100%. I'll phone Worcester Technical tomorrow when I'm there but, hate doing that if I can help it- I wish it wasn't intermittent :-(
If anyone could advise I'd really appreciate it.
Thank you
James
Bearing plate easy to do
Thanks Shaun. I've never done one :-( Always a first time! :)
[automerge]1600805275[/automerge]
[automerge]1600805533[/automerge]
Hi Shaun! Went out to it again today. Bearing was stuck as you suggested- absolutely top advice! Easy to fit too, also as you said (found an excellent video on you tube). Thank you so much!! James
Reply to Intermittent EA fault on on Worcester Greenstar 38 CDi GC 47-406-38 in the Gas Engineers Forum area at PlumbersForums.net
I have a 16 year-old Worcester Bosch Greenstar 35 CDi combi boiler, which is recently suffering from intermittent issues with the hot water. I...
3K
Hi I have an oil worcester bosch greenstar heatslave ii combi boiler. It's about 5 years old. The problem I have is when the thermostat calls for...
3K
Condensing boiler installed by local Gas Safe plumber in 2014, not combi. Failed a couple of weeks ago with flashing blue light which googling...
4K
Hi All, I have a Worcester Danesmoor 20/25 oil boiler which is causing me lots of heartache and grief. About 3 months ago it locked out and...
2K
Hi I am wondering if anyone can give me some advice/help with this issue. I have a Worcester Greenstar 30i ErP which got it's first yearly...
4K
