Discuss Intergas pump over run in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Leo21
Subscribed
Alreet fellas, does anyone know if the compact 24 ov needs a pump over run. I've got to price on without the facility, and I don't fancy a Potterton.
[DLMURL]http://www.intergasheating.co.uk/flip-883247-08-Compact-HRE-OV-Installations-instructions/download/883247-08-Compact-HRE-OV-Installations-instructions.pdf[/DLMURL]
done it for you!
Reply to Intergas pump over run in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My central heating is run off a heat pump ( air to water ) quite expensive to run , So I’m plainning to fit a wood burning with a back boiler to...
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
Hi we have a Alpha 2 15-60-130 central heating pump fitted. We need a bit more heat from 12 rads. I’m confused about the settings as the Auto...
