Discuss intergas or viessmann? Maybe something else!? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
So, I need a system boiler.
5 bed, 2 bathroom, 3 underfloor zones(25sq m/26sq m / 12 sqm), 2 radiator zones(upper and lower), hot water(mains pressure 250ltr oso).
I was looking at a viessmann, then an ideal gen2, however have been looking into the intergas system boilers.
Are they that good? boiler needs to be 27-35kw.
Any better ideas? Thanks in advance.
Strange question, I could set the boiler up with the zones and water cylinder as needed, however also use the hot water side of the boiler to run the kitchen etc? The boilers in the kitchen, so if it'll do hot water also, then it just means a much shorter pipe run to the sinks etc? In effect i'll have mains pressure for the showers and the combi side for the kitchen/utility?
got ya head screwed on right, lots of ways to control these boilers too OT,WC, PDHW
Nice boilers a new model due out shortly a with centre flue the xtreme .kop
As above KOP has mentioned really good interior designed boilers. However, you will always get different opinions from each installer. My preference is Vaillant and especially in your case i would have gone with the exclusive green iq exclusive 627. This system boiler doesn’t need any zone valves which could go faulty at any time too which saves you from hassle. Furthermore the boiler is self modulating which means it modulates between 3.4-27kw ... currently you may not need the full 27kw but 15kw so it won’t use the whole lot.
So there's not a diverter/ zone valve inside the boiler :D
No as the boiler sorts all that out
As above KOP has mentioned really good interior designed boilers. However, you will always get different opinions from each installer. My preference is Vaillant and especially in your case i would have gone with the exclusive green iq exclusive 627. This system boiler doesn’t need any zone valves which could go faulty at any time too which saves you from hassle. Furthermore the boiler is self modulating which means it modulates between 3.4-27kw . currently you may not need the full 27kw but 15kw so it won’t use the whole lot.
how do you control zones without zone valves?
Reply to intergas or viessmann? Maybe something else!? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
