Discuss Insulated pipework in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Deleted member 7121
Hi all, Got a boiler to fit in a outhouse about 10m from house need to put pipes below ground has anyone used pre insulated pipework to do this and if so which brand ? Would need to be 15mm and 22mm
cheers in advance
I once used some underground ducting with some very thick walled pipe insulation, has never been a problem, however 10 m is some going, what about your gas supply, wheres the meter ?
phew, good job eh.
Forgot t mention I used the armflex/climbflex type insulation not the usual gear.
Reply to Insulated pipework in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, Looking for some advice on my little bathroom project. I took the bath out. I got a shower jacuzzi thing. The base has 2 wheels in the corner. Do I assemble the unit first attach water and elec, and slide the very heavy unit in on the two wheels? Or do I get the base in the corner and...
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath the boiler is difficult with lots of obstacles, is it okay if I run soldered copper over / across the top of the boiler? It'll be about 4" off the top...
