Discuss Industrial unit boilers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
Kerr Gas 1
Looking for some advice
got called out to quote for a job today and when I arrived at the address I realised it was a industrial unit, has one big room not huge with a couple small offices and two bathrooms and a small kitchen area. They have to combi boilersin at the moment combi 1 heats the big room via underfloor heating combi two does the kitchen area and bathrooms. So the two combis have to be replaced with condensing boilers usually I install worcesters so il probably go with two green star 30si. My question is does this job need a commercial engineer as its a business unit. I've checked gas meter which is a domestic u6 meter
Any replies appreciated
Thats domestic as far as I can see. Just dont exceeds your limits. Pipe work and kw
Forget the comment about the kw. You can't exceed 60kw
yep agree with simon johns, if you was still not sure , hey theres sum reading lol.
Just make sure your not out of scope with your IV make sure you include the meter IV and 10% for fittings... doubt you will exceed but just thought id say, how big is this place? why two combi boilers?
I asked the same question myself, it's a descent size floor space on the main office combi 1 heats this space through Ufh with 8 circuits that's all as far as I can see. Combi 2 heats kitchen/toilet area 3 double rads and also supplies hot water for kitchen. I'd think il call gas safe to be sure but thanks for heads up
No worries, your max IV is 0.035m3, and you meter IV is 0.008m3 so 0.035-0.008=0.027 divide this by
0.00084 per 1 mtr length for 35mm copper
0.00054 per 1 mtr length for 28mm copper
0.00032 per 1 mtr length for 22mm copper
0.00014 per 1 mtr length for 15mm copper
dont forget the 10% for fittings, this will give you a rough idea.
He can't exceed 60kw because he's using a u6
I always thought it was 6m3/hr although they were capable of more normally? Never heard it being translated in Kw before, is there much differance between the two?
Reply to Industrial unit boilers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
