Discuss Incoming Water pressure in the USA area at PlumbersForums.net
We have a viessmann 111 and we was expecting faster hot water flow. I looked at the PRV it is set to 2 bar, the boiler has a 46l storage tank, so will this PRV set to 2 bar affect the hot water flow rate to the taps.
Can the PRV be set higher than 2 bar ?
Regards
Ant
Do you know your mains pressure and flow rate ?
Prv can be set higher and tbh with 5 bar incoming sounds like you need the main reducing as well
Just by not opening the stop tap fully?
no by getting another pressure reducing valve fitted / if your capable of doing it yourself
3-3.5 bar is more than good enough
Reply to Incoming Water pressure in the USA area at PlumbersForums.net
PSxxxxxx
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
