Discuss IMI Range ltd Flowmax water tank question: please help! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
nbr
I have recently bought a house which has got a IMI Range ltd Flowmax water tank from 1993. Our plumber fitted a new boiler in the house (placed in the garage) and it seems that in order to have the central heating on I have to set the programmer/controller so that the hot water is on as well. If I set the controller into central heating only, nothing happens and the boiler does not even turn on.
The boiler installer says it may be something related to the wiring of the programmer, but could also be how the whole central heating is supposed to work with this IMI flowmax water tank.
I would like to have either the hot water OR the central heating on, i.e. separate, since filling the water tank with hot water to then get the radiators hot feels like a waste, but I am not an expert.
Can you please help? The plumber says the system is too old and he has no idea (?)
Thanks!
Hi all,
I thought I would upload some pictures of the water tank/plumbing system, just in case it helps. Any plumber sufficiently lon enough in the industry to know an IMI range ltd Flowmax water tank from 1993? Any reply welcomed!
Thanks!
Reply to IMI Range ltd Flowmax water tank question: please help! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
