Discuss IFLO CH boiler switch (problem setting only heating for frost protection) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
plumb01
IFLO boiler switch:
I have separate settings for both hot water and heating. However, when I want to set the heating by the thermostat whilst I am away (ie. for frost protection), I seem to have to set both the heating and hot water to "ON" rather than just setting the heating to ON. If I only set the heating to ON, the boiler doesn't kick in until the hot water is also set to ON.
Grateful for any suggestions.
Programmer set to gravity or if it's just started to happen then a faulty control valve in the airing cupboard maybe, such as the 3 port valve
Reply to IFLO CH boiler switch (problem setting only heating for frost protection) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
