Discuss Identification of this cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IMG_1570.jpgHi can anyone tell me what cylinder this is? There are no manufacturers labels on it and it comprises a hot water cylinder and above it, all brazed together, is semi circular cold water cistern and small F & E.
Cheers
Combination cylinder by the sound of or, but they are usually directly on top of each other
Reply to Identification of this cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
