Discuss ideal mexico pilot light in the Plumbing Jobs | The Job-board area at PlumbersForums.net
g60rge
pilot light goes out in heating mode after 30mins, but stays on for hours in hot water mode. how is this possible?
Could b loadsa things.
Could be boiler running a lot in heating mode in badly ventilated room. Oxygen level drops, pilot light lifts searching for oxygen, flame loses contact with thermocouple and goes out.
Could be dodgy thermocouple.
Cant remember boiler well does it have safety switch in flue or overheat stat through an interupter in thermocouple like Sime atmospherics have.
One of these devices could knock out pilot light.
public room guys lol, but yeh wot spark said , find out when last serviced because me personally id replace the thermo for all the cost and you know yourself replacing the thermocouple means removing the burner so your aswell sticking the hoover in while shes open and clean out injector and check spark etc, then see if problem persists,
Oops, forgot there kris yer right on the giv it a new thermo and clean by d way
The flame lift and duration on heating is not as continuous as how water, simple TC change will probably sort it
Reply to ideal mexico pilot light in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
