Discuss Ideal logic system18 problem with intermittant leak inside boiler casing only install in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Re: Ideal logic system18 problem with intermittant leak inside boiler casing only ins
are you gas safe registered if so can you pm me or another mod /admin your gs number so we can confirm this,how old is the boiler,is it in warranty?
im in the rep of ireland and registered with RGI ireland
Boiler only installed 3 weeks ago so it still in warranty
cool whats your reg number with RGI,the answer we give will depend on us knowing you know what your doing and not killing yourself
call ideal in,unless your flues got issues and its leaking condensate back through
r3780
I checked the condense trap all seemed ok and all flue seal ok standard horizontal flue ive just heard they can be a bit dodgy with leaking h exchanger and was wondering if anyone came across any issue like this
i dont think they are having many issues at the moment TBH i have only installed 2 prefere pottertons,if its that young kick it in would be worth you joining the gas safe (or rgi only forums) by dropping a private message with your details to a member in admin,that way you can ask any gas questions you want without everyone wondering if you know what your doing first,sorry for the inquisition and welcome to the forums,though a lot of the lads do fit the logics all the time and may be able to advise
yeah i have fitted a few myself and they seem to be decent enough boiler this is the first issue ive had with one but looking at uk boards ideal have a bad name and ther wouldn be too many installers over here that would be too familiar with the problems the ideal boiler gives so thats why i came on here. i dont think the rgis have a forum set up over here anyway just dedicated to installers
Reply to Ideal logic system18 problem with intermittant leak inside boiler casing only install in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
PSxxxxxx
