Discuss Ideal Logic system s30 boiler making whistling sound in the Central Heating Forum area at PlumbersForums.net
Hi guys, my boiler seems to be making a whistling sound after a while its on, if I tap it firmly it goes away, is this something to do with trapped air? Any ideas? My boiler is ideal logic s30. Video attached
thanks
  • FB85B49E-7D9E-4FFA-A353-FFD3E16D4A21.MOV
    15.3 MB
Reply to Ideal Logic system s30 boiler making whistling sound in the Central Heating Forum area at PlumbersForums.net
Hi I have a Ideal Logic S30 System Boiler, and I have always left it on eco setting which is 70 degrees. I have a separate thermostat for my...
2K
why does my idea logic +30 system s30 boiler stopped heating my water??
Deleted member 120897
Hi everyone, I waited a while before I posted this as I wanted to see how long the issue would go on for. There is a whistling sound from the...
Equipment The shower (a cold feed electric unit) and the Kingspan tank are on the top floor of a 3 storey building. The Ideal Boiler Logic Heat 15...
Got up on Wednesday morning no hot water, (only cold water coming out of hot tap). Checked boiler, it had zero pressure and F1 fault showing. So I...
