Discuss Ideal Logic Plus 30 - loss of pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi , you all have probably seen this problem but as im new to this i cannot seem to find the solution.
We have an Ideal Logic 30 Combi boiler 4 years old and we are having to top up using the filling loop almost every other day. My boiler engineer assures me its not the boiler at fault although he hasnt visited as he really cant be bothered or too busy! so i need to confirm if there is a leak in the central heating pipes somewhere. We cannot find any signs of pipes leaking in the house at all but another plumber suggested somehow isolating the boiler (using the filling loop ? )increasing the water pressure to 4 or 5 bar (as over 3 bar pressure the boiler valve will dump ?) and listening for any leakage in the house. Well im a carpenter so that all went over my head as its not wood related. so what does he mean , can i check that its the pipe system leaking and not the boiler by somehow isolating the boiler ? Many thanks , sorry for the poor description ! KenE
You need a qualified engineer to look into this for you. If your plumber won't come round to sort it, threaten to cut the bottom off of all his internal doors :)
Reply to Ideal Logic Plus 30 - loss of pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
Hi, We have a new Ideal Logic Combi 30. A radiator today came off the wall and developed a leak. Plumber came and fixed (but didn't). At that time the boiler was fine. Today the boiler has lost pressure. I have followed the videos on yt and nothing works. Just stays telling me F1. I have...
FrankMcg
F
Got up on Wednesday morning no hot water, (only cold water coming out of hot tap). Checked boiler, it had zero pressure and F1 fault showing. So I refilled the pressure using the filling loop, up to about 1bar which is where it usually is, which worked fine, had hot water all day. Same thing...
1K
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and plasterboard celling. I have got unvented pressurized RM Cylinders hot water system with 27KW Worchester gas boiler with expansion vessels . When...
losing pressure
L
I have a Vaillant eco plus 837, year installed 2008. It works well. We have one large zone for the house with 13 rads running off it. We also have an UFH zone in the kitchen. Near the boiler I have 2 port valves which control this part of the system. The boiler has been loosing pressure...
I've got a 2016 Logic PLus Combi 30 and a Salus RT505TX RF Thermostat The thermostat seems to keep losing connection, no matter the placement. It can be next to the boiler or in the next room and it still not get a connection. Just a weird blackspot in the kitchen blocking it (could be the...
