- Messages
- 34,368
- Solutions
- 2
Why do you need to replace the pipes ?
Discuss Ideal Logic Heat 15 with FD error in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
The dog deicded to have a nibble on it, got half a dozen small punctures in itWhy do you need to replace the pipes ?
Thanks KOP, always there with sound advice. Just to clarify, when I remove the pipe, is it just a case of inserting a new lngth of pipe, or do I also need new fittings?This is a easy fix for a pro but a pita for a diy'er fittings you simply push the collar in using the correct tool or small adjustable spanner then pull , the water pressure will need draining before carrying out the repair , obtaining a short length of pipe and cutters is your first issue ? fittings and linners are readily available at plumbers merchants. Regards kop
Glad you got it fixed best keep the doggies away in future
Reply to Ideal Logic Heat 15 with FD error in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
