Discuss Ideal Logic combi 30 - warm water only? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
keveen
I am looking after a Ideal Logic combi 30 which has needed frequent emergency care since installation 4 years ago! If it was a dog you might consider putting it down...:33:
Anyway, the water has started to be just warm rather than hot. The CH is fine.
I turn on the hot water tap, I see d (for direct water) I hear the click of the ignition and see the blue light and can hear the normal sounds. I turned the water temperature up and it runs a bit hotter.
I think a similar thing happened 3 years ago. The Diverter valve was leaking so had both parts replaced.
Is this a symptom of the same thing or something else? Maybe the thermistor (I read) or flow valve. I remember their was occasionally some hard occasional banging in the taps upstairs a few weeks before if that is relevant.
I'm just looking for advice before I call somebody out so I don't wast money on the wrong fix.Thanks.
Why the automatic assumption we don't know what we're doing?
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
[DLMURL="http://www.co-gassafety.co.uk/deaths.html"]CO Gas Safety[/DLMURL]
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to Ideal Logic combi 30 - warm water only? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
About 5 year ago, I had a new central heating system (radiators) installed to replace my old warm air underfloor system. The warm air side of the...
Got up on Wednesday morning no hot water, (only cold water coming out of hot tap). Checked boiler, it had zero pressure and F1 fault showing. So I...
1K
Hi all I have a problem with my hot water header tank getting warm water into it from the bottom of the header tank (not the hooked...
F
Hi, We have a new Ideal Logic Combi 30. A radiator today came off the wall and developed a leak. Plumber came and fixed (but didn't). At that...
FrankMcg
F
J
Turned the system from hot water only, to hot water and central heating the other day. After it working briefly, it has now stopped all together...
James Middleton
J
