Discuss Ideal logic combi 30 problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi all
Seem I've had a few problems lately with this little gem of a boiler, she's about 7 years old.
Usual issues, pressure dropping, needed topping up every 3-4 days
Not visible leaks detected.
Then the hot stopped working so I changed the flow turbine which solved the problem also while I had my head in the boiler I changed the expansion vessel which was a good call as full of water, bought one off eBay, not quite the right size but made it fit.
Boiler worked fine for a couple of days but now is losing pressure badly every day needs topping up, still can't see any visible leaks inside, however the condensation (plastic pipe) out side I can see water has been coming out.
I'm going to change the prv this week to rule that out.
Any help would be great
James
You must be Gas Safe to take the case off your boiler. Otherwise you are working on the boiler illegally. You need to send your gas safe number to @Lou or @Dan and they will sort you out.
Reply to Ideal logic combi 30 problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Got up on Wednesday morning no hot water, (only cold water coming out of hot tap). Checked boiler, it had zero pressure and F1 fault showing. So I refilled the pressure using the filling loop, up to about 1bar which is where it usually is, which worked fine, had hot water all day. Same thing...
1K
F
Hi, We have a new Ideal Logic Combi 30. A radiator today came off the wall and developed a leak. Plumber came and fixed (but didn't). At that time the boiler was fine. Today the boiler has lost pressure. I have followed the videos on yt and nothing works. Just stays telling me F1. I have...
FrankMcg
F
Hi all, i moved recently in new home and realised that there is no room external thermostat wired to the Ideal Combi boiler. There is only mechanical timer on it. I saw some videos on Internet that mechanical timer can be replaced with electrical one but i am not sure if it is compatible with...
Dobsuk
J
Turned the system from hot water only, to hot water and central heating the other day. After it working briefly, it has now stopped all together. The display isnt showing a fault or anything - it is just blank. After reading the service guide that came with it - I am confident there is power...
James Middleton
J
My heating system comprises an Ideal Logic 12 boiler located downstairs and a Gledhill OV SOL cylinder located upstairs . The problem is that when the Gledhill controls for the “hot water” and “central heading” are turned on the Ideal boiler makes a constant “clicking” noise and tries to start...
