safeplumb
Hi Guys can you help,
I had to recently drain down my Ideal Isar HE24 boiler to fit a new drain off tap on the heating return pipe which was leaking. Refilled and everything is working fine except for the pressure guage which reads 3 bar when the heating is running, when the heating goes off it stays at 3 bar. If I drain out some water till the pressure guage reads 1 bar and then rerun the boiler the pressure guage eventually goes up to 3 bar again and stays there when the heating goes off. Did not have this problem before I drained down to fit the drain off tap. Any ideas?
Cheers Al
Cheers Al
