Discuss Ideal Classic FF370. in the DIY Plumbing Forum area at PlumbersForums.net
R
Roger Barnett
I am trying to locate a Boiler thermostat sensor for an Ideal Classic FF370.Not having much luck.Does anyone know where I might find one; or a similar compatible sensor, Thanks. Roger.
Reply to Ideal Classic FF370. in the DIY Plumbing Forum area at PlumbersForums.net
I have an issue with a Worcester Greenstar 29CDi Classic boiler. I replaced the old thermostat controller with a smart dual-channel HIVE one. I...
Got fd code on Ideal Logic Heat 15. Had two plumbers out and no joy. It’s had a new water flow sensor, flush with sentinel x800 and refurbished...
Hi all, i moved recently in new home and realised that there is no room external thermostat wired to the Ideal Combi boiler. There is only...
Dobsuk
Hi all, I am trying to find an alternative flush valve to fit the cradle of a ideal standard push btn flush. It is all tiled in and changing to a...
Evening All, Been having on and off issues with a Greenstar CDI classic Combi were the hot water is not heating up but only intermittently. Some...
