L
layman1
hi,
i'm new, first post so please be considerate if i'm repeating what has already been discussed - i did do a search but without success.
my system; gravity fed, indirect HW, S plan, gas boiler that is at least 15 years old so non-modulating non_condensing i.e. inefficient but i'm kind of attached to it because it works and works well. cold water and expansion tanks as per gravity fed system in the attic above airing cupboard. TRVs on all rads except the one located nearest the thermostat and the bathroom radiator which has 2 lockshields and is from my lay point of view a bypass radiator - it is not controlled by either of the motorised valves and is immediately after the pump but before these valves. there is also a single gate valve in this mini bypass circuit.
so to my question:- it's late spring now and the heating circuit has been turned off on the boiler programmer. we only require hot water for hopefully the next 4-5 months. i'd like to avoid wastefully heating the bathroom everytime the hot water is heated. how best to achieve this and remain with a safe system that is not going to overheat? Does the pump run for several seconds after the HW motorised valve shuts off therefore requiring the bypass radiator to avoid flow restriction in the 'hot' boiler?
hope this doesn't sound too stupid and i look forward to some sensible solutions from experienced heating engineers
regards
layman1
regards
layman1
