Discuss How to fix leak with too much ptfe tape in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
A
Adam davis
Both Tiny leak on bot new fits on the metal nuts. Did i use too much ptfe tape. I used 2 wrap arounds. The nuts won't tighten anymore. Could i remove the exposed ptfe tape and if so would the nut then continue to tighten and is this a ok thing to do. I should have used 1 wrap around i know now.
Reply to How to fix leak with too much ptfe tape in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
