Discuss How to add water to system- Vaillant Ecotec Pro in the Central Heating Forum area at PlumbersForums.net
How do I let water into the system? Tap is connected to water tank and there is a black inlet connected to the water tank? Thanks for any answers
Use the two levers either end of the “hosepipe” that has an orange stripe on it.
Open the red lever at the wall, not fully at first, then open the small black lever at the other end of this pipe. Make sure both are off after use and ideally this pipe should be disconnected and the caps fitted.
Not locked just stiff the lever will turn one way
Reply to How to add water to system- Vaillant Ecotec Pro in the Central Heating Forum area at PlumbersForums.net
We have hot water, tank for hot water why is the hot water boiling hot from tap,and shower, We are on a schedule for hot water via our hive app...
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
