- Messages
- 9
Discuss How much to re-level a walk in shower floor? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
I seems to be an issue with the level of the floor rather than the drain as when I turn the shower off the water just sits there, pooled in the lower left corner of the image (I have mopped up the water so you can't see in that image). all water by the drain disappears. Roughly how much would it cost to rip it up and re-level it and re-tile?Needs ripping up and starting again as something is wrong if the level has moved / dropped
Drain clear / clean ?
Many years now. Since 2004How long has it been down ?
It was built in 2004 so all the work was done before I moved in. What do you think possible causes could be? Building subsidence?That's not a terribly short lifetime for a shower. Problem is finding and fixing the cause of the fault. Did you have the work done?
Reply to How much to re-level a walk in shower floor? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
