Discuss How much does it cost to heat water per hour? in the Central Heating Forum area at PlumbersForums.net
Hi guys
trying to work out how much it costs to heat my water tank per hour, I have a Ideal logic system s30 boiler, my gas unit charge is 6.83 pence. Anybody work that out for me roughly please?
What’s the cylinder? Unvented should have a kw coil listed on it ?
The cost to run the boiler at rated heat output can be estimated:
Central Heating Max. Output:
30.3​
kW
Assumed boiler efficiency:
90%​
Gas price:
0.0683​
£/kWh
Cost to run boiler at rated output:
£2.30
/hour
The heat delivered will depend on the rating of the coil in the cylinder and will decrease as the temperature difference between the water in the cylinder and the boiler flow decreases. The thermostat will stop the heating when the water reaches the set temperature. At rated heat output it would take less than one hour to heat the cylinder from cold. The cost to heat the cylinder from cold can be estimated:
Cost to heat 300 kg of water from 5°C to 60°C
Specific heat of water :
4184​
J/kgK
Hot water cylinder capacity:
300​
kg
Temperature increase from 5 to 60°C:
55​
K
Heat required:
69 036 000​
J
Conversion factor:
3 600 000​
J/kWh
Heat required:
19.18​
kWh
Gas price:
0.0683​
£/kWh
90%​
£1.46
Usually the cylinder will not be cold. The cost will be lower depending on the amount of hot water that has been used. There will also be heat loss from the cylinder. Each time the cylinder is heated there will be residual heat in the pipes between the boiler and the cylinder that may be lost, especially if the central heating is not on.
Thanks very much for this, im trying to find the coil kw capacity, is that the immersion coil? , theres a sticker on the water tank but no mention of coil capacity
No not the immersion
Should be a kw value eg kw rating or primary coil etc
Only got this label on the tank
That will do around 26kw is the coil rating
So around 1.20 to heat fully a day
Reply to How much does it cost to heat water per hour? in the Central Heating Forum area at PlumbersForums.net
