Discuss How long can I leave in Sentinel X400 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
ABB
Hello,
I’ve got a build up of sludge in my system so wanted to run a cleaner through. I have a magnaclean fitted so was hoping to add Sentinel X400 to the system and leave it in indefinitely - just cleaning the magnaclean weekly for a few weeks until it runs clean rather than draining/refilling system.
In theory is there any problem with leaving X400 in the system indefinitely? If so is there any other product that will do the job I want and can be left in the system permanently?
Appreciate any advice.
Hello,
Call or email Sentinel is your best bet.
Just read the instructions:
https://www.sentinelprotects.com/si...t-sheets/sentinel_pfs_x400_uk_v5_jan_2019.pdf
This says that you can leave X400 in the system indefinitely but it only keeps the sludge in suspension for 3-4 weeks, i.e. for full effectiveness you need to drain/flush and refill with clean water and inhibitor within that period.
The problem with your no-drain/magnaclean approach is that not all the components of sludge are magnetic so they'll stay in the system unless you drain.
Reply to How long can I leave in Sentinel X400 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I’ve recently cleaned my central heating system with Sentinel X400 cleaner, flushed it out clear, refilled & added Sentinel X100 inhibitor. After...
1K
Hi I have recently bought a house which is 17 years old. There was a small leak from one of the radiators So I took the pipe off and drained the...
Hi, Can anyone offer me advice, I’ll try and keep it short! Just cleaned my magma cleanse unit, and it wasn’t too bad since last boiler service 1...
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
A bit of history first. 2 yrs ago visited a grant boiler with boiler and pipework kettling. I added SentX200 noise reducer. It is standard open...
