Discuss How do I realease pressure from combi boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I over pressureisd my boiler after fitting new radiator. It’s now just ove 2bar when working how do I release some pressure from the system? Thanks.
Morning. We do not judge the level of pressure in the system when hot. If it is Between 1 and 1.5 bar when cold, this is fine. If not get a jug, vent a radiator and catch the water inside the jug until the pressure is at the correct level.
If it's fully hot and doesn't go over 2-2.5 bar your fine
If it goes higher just get a container and bleed a rad
Good advice here about the high pressure. But I would not recommend bleeding rads when they are hot. To easy to scold yourself. But that's just my opinion.
Depends how careful you are :D
Reply to How do I realease pressure from combi boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all Noticed bad smell in my drain out side put my hand down and it unclogged it for now however I checked my sewer drain and after flushing my...
