scon1
I have been using the presoldered joints for a while, usually with no issues. Recently I have had a series of bad joints on a hot water pipe. Am I missing something?
Turn off water, open tap for vent.
I clean the outside of both pipes with wire wool.
Thinly smear flux over the outside of all pipes.
Slide on T joint, to the 3 pipes.
Light Butane / Propane mix torch, get blue flame.
Wave inner blue flame over the T piece, bottom, middle then top.
The bottom and middle joints have the solder bubble out from end.
The top joint remains dry.
The joint is fairly tight against a wall, but I have tried to heat the back first.
After testing, top joint has slight leak. Reheat joint, adding more solder but solder just falls off.
Any ideas?
I have never had a joint so difficult to seal!
Any ideas?
